Caporegime
- 9 Nov 2009
- Planet Earth
Well that is good that it got fixed, because AMD looked dreadful at first.
All things being said though, they are pretty equally performing cards if you look across a whole spread of games.
I just couldn't understand why the other guy was so amazed that the 290/390 could keep up with the 970 when they are essentially in the same performance/price bracket. There are always and have always been games that one vendor does better in than the other.
Which again meant nothing since above 60FPS the engine Bethesda used screwed up physics - it is the same issue they had in previous games.
So all the people shouting "terrible" actually never had run some of the Bethesda games beforehand - the engine they used is ancient. It is a modified engine based on the one in Skyrim which showed the same behaviour.
Reviews edited files so they could enable higher FPS which meant physics were screwed up.
The R9 290 series was launched at the same time as the GTX780 and was trading blows with that. The GTX970 was destroying the R9 290 series. I am amazed since that even after 2.5 years,it seems competitive even though "Dat' Gameworks effect" and "AMD rubbish drivers(tm)" it seems to held its own.
Plus many of the R9 290 reviews are still using the fail reference cooled model and it is hard to say whether they have tested with the newer drivers or not.
The non-reference models launched within two months or so of launch are less likely to throttle,so in the end the R9 290 series cards have done well.
Plus,the fact that a repainted R9 290 is still competitive shows that the base GPU has had incredible staying power.
TPU- GTX970 launch
R9 390 review this year
I also made sure I linked to 1920X1080 numbers too,which tend to favour Nvidia generally.
