Hello fellow nano owners. So may be a silly question but i just need clarification. Looking at getting a 144hz monitor (benq xl2430t). My question is hdmi wont go up to 144hz on the nano so will the display port and do i need a active cable?
Cheers
zip-tie through the holes is what I was thinking of mate![]()
Cheers ��
Right, I've just pulled the trigger on one of these:
Asus R9 Nano with free Far Cry "primal" game for £359.99p
Once its installed and running I'll post up a load of questions which I'll invariably have, regarding overclocking, though I'm not expecting much headroom.
The VRMs get pretty hot.......
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/70246-amd-r9-nano-review-3.html
The amount of noise this pint-sized card’s PWM puts out is nothing short of astronomical. It wails, squeals, chugs and emits all sorts of other electrical blather. Granted, some gamers will be more susceptible to hearing it than others and there are certain cases on the market that will reduce the amount of perceptible noise but this is still unacceptable on any $650 card released in 2015. AMD is aware of this but they don’t count it as a problem. We will have to see how widespread it is once the Nano gets into the hands of end users. It is important to note that we're not sure how widespread this is or whether or not we received one of the "louder" samples. We just report it as we see it.
Just sending my Nano back, hoping they find a problem because if it's not the nano i don't know what to do next.
AMD Matt do you find its a universal nano problem or does it affect some more than other? Is there much difference between manufacturers in other ways ie XFX vs. ASUS vs. Powercolor?
I think they got a broken one. Neither of my Nanos is remotely like that, just a faint touch of coil whine.Glowing review of the Nano, I see![]()
Still waiting on mine back from the manufacturer. Hoping I get a replacement as it may have less coil whine too.
My 8800GTX used to whine like mad too, maybe try different frequencies to see if its worse at certain speeds, and also play with the voltages?
I've recently gotten hold of a nano, it's pretty quiet in gaming - much more so than the Palit 970 it replaces. There is some whine, but isn't that loud and can't really be heard much over the fan.
What is annoying though is the idle fan speed of 1500rpm, makes it by far and away the loudest component in my system so may need to see if something can be done to shut it up or something.
