.The owner is pulling your leg buddy, an X on stock turbo cannot make 470BHP, that is new bigger turbo and uprated conrods to handle that level of power. The stock engine and stock turbo absolute maximum is 440BHP and at such power they have had the stock engine and turbo let go. I know I used to own one of these cars and did a lot of research when I owned mine and the most power I could make reliable was around 420 ish whilst maintaining stock power delivery.
I think the owner judging by his blacked out lights, BC coilovers and impossible 470BHP is either dreaming and never actually dyno the car on a accurate dyno so is just making up bigger numbers.
Judging by the modifications the owners has done it on a tight budget and I'd be really steering clear of that car and looking for a stock one or one with at least more tasteful modifications.
The EVO 5 your looking at seems to have being modified to much better taste with a lot more money thrown at it, Ohlins coilovers, now were talking those are the real deal that ride superb on both road and track, not just a one trick suspension but that is why they cost 2-3x more than a set of BC's.
My worry over the EVO 5 is it is clearly highly strung, hence engine rebuild and its only done 1000 miles so its not a particular well proven and reliable car unfortunately.
P.S. The SST gearbox cannot handle more than 360lb/ft without modification, this is why it was only available on FQ-300/330 models, 360 and above it was not an option.![]()
here are the specs for the white X Gibbo :-
2009 evo x fq300 with 34,000 miles will raise slightly as being used in spare time
*ecutek remap running 476bhp with mild pops n bangs
*forged bw i beam conrods with arp bolts
*cosworth 1.3mm head gasket
*10w-50 titan pro s oil
*later modified timing chain
*mhi billet turbo
*1000cc injectors
*ets boost pipes and filter
*jmf tublar manifold
*tomei wide mouth down pipe
*miltek back box also have smaller ets back box
*forged alloy inter-cooler
*forged breather kit
*uprated fuel pump and 3 port boost solenoid
*500lbf Dodson club man clutch plates
*B.C coil overs with indigo fast road setup
*new ayc pump with uprated motor
*4 matching ad08 tyres
*all engine and gearbox has 7 months warranty via indigo gt only covered 3000 miles since built runs and pulls perfect as you will know ant at indigo knows his stuff
