Hi all, am after a bit of advice regarding my brand new S7. Straight out of the box it has white marks near the top of the screen which are very visible on a white background.
The below image has the marks highlighted, the image does not full capture how bright these marks are, they are very distracting.
http://postimg.org/image/xr0dr7kyf/
My question is, would this be grounds to get the phone replaced? If so, would it be through Samsung directly or through the company I bought it from, Very?
Thanks for any comments!
I used 3.10, I had seperate files I put them all in the right section of ODIN, I didn't use the CSC marked HOME, I used the other one. That will wipe the phone but doesn't cause the hang you had.
Backup with smart switch to your pc and restore after, the phone is pretty much as you started barring a few settings I had to adjust.
Any of you chaps use the Package Disabler apps in the play store, how much difference are we talking about when a bunch of apps are disabled? Battery and speed wise that is.
I've started seeing voLTE in the status bar for the last few days, anyone else see it?
