I bought all my car cleaning kit months ago and have only just got around to doing a proper full clean rather than just soap and a wash. Spent about 4.5 hours and my arms are absolutely ruined, I've been swirling for hours. Next time I'll have to use machinery
So it was a pressure washer pre-wash, wash with Meguiars Hyper Wash using Dooka wash pads and EZ detail brush for the wheels, rinse off with pressure washer, dry with microfibre drying towel. Next up was claying with Bilt Hamber regular clay then rinsing off and giving it another wash all over with the hyper wash. Then I polished it with Autoglym Super Resin Polish and Farecla G3 waffle pads and buffed off with some microfibre cloths. Then I glazed it with Poorboy's black hole (which smells of awesome blueberry's) and the Farecla G3 waffle pads and buffed it all off with another microfibre cloth. Then finally I waxed it with Collinite 476 and the Farecla G3 waffle pads and buffed that off with another microfibre cloth.
It's difficult to compare compare because the before photos were taken in bright sun around 12pm and the afters in shade around 5pm. Doesn't look as pink now at least
Before:
After:
Before:
After:
