Plastic chrome? Maybe it wasn't looked after so well before you got it.
Old wheel caps off.
WTF happened to these !
Probably all that acidic wheel cleaner car washes use
Stop sticking LED's and pressed plates on that poor M3![]()
Replaced the keyfob emblem. The old one was a bit naffed up!
Dat peeling feeling![]()
Doesn't sound that great actually, maybe a box is for the best. I'm used to the sweet music of ITB's on 4AGEs and CSLs.
My Mondeo's rear arch has been deteriorating for a while now, I already know that it's had a scrape & a repair from the previous owner as there is filler in there.
It was starting to bulge so I thought something had to be done -
[IG]http://img.photobucket.com/albums/v463/iamzod/20160501_121103_zpswyynuhps.jpg[/IG]
I started cutting the paint back & found a rusty bit, obviously this has not worked around from the lip as the lip was comparatively clean. A bit more poking and it turned into a hole.
[IG]http://img.photobucket.com/albums/v463/iamzod/20160501_125241_zpsaczmh68e.jpg[/IG]
[IG]http://img.photobucket.com/albums/v463/iamzod/20160501_133925_zpsrdp99brr.jpg[/IG]
I ended up cutting a 2" by 2" section out of the arch as it was rotten, the problem is it was too windy to do any welding so I've had to do a temporary fix & use fibreglass until I get a dry weekend where I can do some welding on it, in the meantime I am going to see if I can get my hands on a clean wheel arch section and then just cut the whole wheel arch out and replace it with a clean one.
The problem with working on this car unlike my Capri is I need it on the road 5 days a week so have to be quick.
It looks like this now, not too noticeable & if it lasts 2 months 'til I can sort it properly i'm happy -
[IG]http://img.photobucket.com/albums/v463/iamzod/20160502_193509_zpsw5yafrmp.jpg[/IG]
Drove the Octavia to work for the first time this morning, it was great. Much much quieter, much more relaxing, less gear changes required, really light clutch, and it averaged an indicated 64.6MPG with a mixture of 65MPH (GPS) driving on the motorway, and heavy traffic!
Ordered some new mats, new heater control knobs, and new numberplates for it too. Just needs an armrest now and its all systems go.
