It won't and why should it?
Why wouldn't you want it
As you have said many times about wanting AMD to do well because it benefits the end consumer in the end.... If given the choice to nvidia users, would you not much rather have a far larger choice of monitors/panels to choose from, not to mention generally much cheaper ones.
Since you mentioned your interest in a 34" 1440, the freesync version is currently £350 cheaper than the gsync equivalent, imo, the gsync version is not worth the extra considering the only difference will be better motion clarity (which comes at the cost of possibly coil whine and
scanlines, which can be somewhat fixed but it requires a bit of faff) and to get that benefit, you will need to be pushing 75+ FPS, which is pretty much a no go in most new AAA games with all the current single GPU's unless you are ok with dropping settings.
If pascal has DP 1.3 then that is all that is needed to make use of adaptive sync AFAIK. As I have posted before, only ways nvidia can avoid this:
1. don't include DP 1.3 but that is going to cut of a lot of future monitors and the likes of 4k with 100+HZ refresh rate
2. they get the monitor manufacturers to disable it on the firmware side (unlikely especially when intel will have support for it)
3. they disable it in their own drivers and I wouldn't be surprised if some kid re-enabled it via a hack
Every G-Sync module is tuned to work with the panel it is in and this in turn stops any flickering or other potential issues.
I haven't really seen many reports from freesync users having any problems (any problems are usually down to the monitor i.e. backlight bleed), in fact, the only issue I have read lately is that "some" have problems with the x34 freesync flickering when using freesync + 1440 + 75HZ + 8 bit depth, when dropping to 6 bit, the flickering is gone, but like I said, only a few have reported this, so chances are there is something on their end that is wrong, otherwise all AMD users would be reporting this.
EDIT:
And yup inb4 the comments of gsync being "superior" arrive:
https://forums.overclockers.co.uk/showpost.php?p=29453135&postcount=618
