625mm here (same as my kitchen worktop), which is plenty deep enough for me...although it does look quite narrow in my pic.
Think you're right about 900mm being too deep though mate. Would just look a little odd I think, considering the Alex drawers are only 580mm deep.
Worktop (prime oak from worktop express) was originally 2m, but was cut down to 1.8 to fit my office better.
What is the height from the floor to the worktop? interested in having a simular setup within my living room
Gave the desk a clean up today, few cables still to tidy. Shelf looks badly bent in the pictures. It is, but only by about ~1mm at max. I suppose a slight angle for the photo's doesn't help.
Managed to cram an Xbox One, A100 amp and BX2's, four way-RCA switch, U3415W, Pi3, headphones and PC set up into little more than one metre.
Dark picture to show possible backlighting in future? Just as a thought.
Oh, and the benchmarks have my CPU/GPU max at 63c. Still nice and quiet with no water in sight!
I want to get the case in the left alex unit but its about 1 inch too long, ive got about 3 inches between the unit and the wall due to the wider worktop so i think im going to cut out the back of the unit so the case can slide in.
Ive also got the cable tray to install when i borrow my dads drill at the weekend.
Good plan. Airflow is likely to be an issue so you may want to put a grille on the front door.
Is anyone here using a combo of Ikea Fredde desk with a 34" UWS monitor? The monitor will of course fit on the desk... Just not sure if it would be too small a gap between screen and user. Thoughts?
Yep...
I'm using a x34 but I got a new desk clamp stand instead of using the huge stock one.
Distance is perfect![]()
Awesome. Thanks easy. Don't suppose you have any pics knocking around?
