- 12 Jul 2015
Melbo- I think! Will check when I get home. Will be on about 2100 hopefully.
Okay just send me an invite then, yeah? TheF34RChannel
Okay just send me an invite then, yeah? TheF34RChannelHow many times have you completed it on CM? If it's more than 0 I'm already jealous
I believe 3rd wave (coincidentaly game has agents waves) bans will clear things up,it wont prevent them buy another cheap account/game key tho
Hardmode is pretty much like the Hardmode Dailies now. you can PUG it easy enough unless you get really unlucky and find a group of spastics
Will do. Completed it about 4 or 5 times now I think. High skill player with pulse and smart cover, one running aid station which negates status effects and the rest running flash and overheal with CONSTANT healing whenever it pops. Add in 2 man mobile cover for added easy times if you struggle with the shotgunners.
yup...pretty much every time I attempt it
Melbo- I think. Post yours here and I'll add you when I get home in an hour or so.
Tell you what, add me on Uplay and I'm going to do HM again after the reset, you join in yeah?
Just completed CM FL with f34r, labby, bigmender!!! Was an amazing run, thankyou!
Learnt a lot doing that.![]()
NP it was a nice run with 2 1st timers glad we helped u pop ur CM FL cherry![]()
