- 16 Feb 2010
- North East England
Im in the exact same boat, if Zen beats my 4770k even slightly im swapping, simple as that.
So you would do an entire system change for a 'slight' upgrade?
I never realized people are so willing to spend money despite having no practical purpose![]()
Sure. With that slight increase in raw CPU performance, you're probably also going to get an upgrade in the memory it supports (DDR4, higher clocks), more PCI lanes, an up to date instruction set, almost certainly lower power consumption and probably other modern features.
It brings with it a whole range of side-benefits even if the increase is only slight. Plus if they have a 4770K their system as a whole probably has things they'd likely want to upgrade as well anyway.
Surely though there is no real danger of AMD getting close to the Broadwell-E performance? It just feels unlikely to me...
I am pretty happy with my 5930k, but I am currently building a beast and looking for a 6950X on launch.... There is no threat of AMD getting close to the Extreme chips... right? And if not, then surely they are still plodding around in the middle-of-the-road nearly-as-fast-but-cheaper bracket?
Cheers
Ben
Cheers
Ben
All of what you listed (memory/pci lanes/instruction sets) merely counts as the 'slight' performance and would give negligible real world benefit to most pc users. Why do you think all threads which ask 'what to upgrade to from Sandy through to Haswell' are met with don't bother, spend the money on a GPU.
My 4770k is a few years old as is my ddr3 2400mhz ram and my z87 mobo, it's either swap them all out soon for an Intel product that will be a slight upgrade but cost a fair bit, or swap them for an AMD upgrade that could potentially be little to no upgrade but could cost a fair bit less than the Intel option.
Also the AMD offerings should hopefully offer more cores for less than Intel offers and if DX12 picks up enough and proves to be better with more cores in the long run its a better investment, especially when I now only really upgrade every 3 years or so
According to an AMD PR guy Zen will compare favourably to Skylake:
http://www.itwire.com/it-industry-n...ll-favourably-compete-with-intel-skylake.html
John has been at AMD since 2006 so I was somewhat stunned when he said with its 7th generation Zen processors (CPU and APU) and new Radeon graphics processors (GPU) that it had finally caught up to, or surpassed Intel’s Skylake offerings. “Zen will compete with Intel on performance, power and specifications – not just price,” he said.
