Urrrrrrrrrrggggghhhhh, filthy console peasants......![]()
Can someone sum up everything since ~4am?
Every time reviews hit there's like 20 new pages to sift through.
if the 1080 can only manage overclocked 980TI performance where does that leave the much smaller 1070? overclocked 980?
I wonder what tech that game uses that The Fury X does so well in it?
Probably, but tbf a VERY well overclocked 980 almost reached Ti performance anyhow. Well, my eVGA's did
God I loved those cards...
I'm eager to know. Have none of the review sited got the 1070?
I'm *really* disappointed in the 1080 if I'm honest. Effectively 2 node shrinks and this is the best they can do!!??? I think they're giving us *just* enough to keep us happy tbh
Can i ask do you think there will be another nvidia card released in time foe BF1 or will it just be 1080s still?
''But at roughly 80 degrees C and at that level the noise levels are okay really. In idle you can barely hear the cooling solution and under stress, well you can hear some airflow and that's it.''
http://www.guru3d.com/articles_pages/nvidia_geforce_gtx_1080_review,30.html
Be that as it may at over £400 initialy and £350 eventually colour me unimpressed.
GeForce GTX 1070
16 nm GP104 silicon "GP104-200-A1" GPU
1920 CUDA cores
15 out of 20 streaming multiprocessors enabled
120 TMUs
64 ROPs
256-bit GDDR5 memory, 8 GB standard memory amount
Max GPU Boost frequency 1600 MHz
6.75 TFLOP/s single-precision floating point performance
150W TDP, single 8-pin PCIe power connector
3x DisplayPort 1.4, 1x HDMI 2.0b
2-way SLI with SLI HB bridge support
