Caporegime
- 9 Nov 2009
- Planet Earth
I did it was in a link someone posted.
I think it probably is Zlatan over on AT forums. Fottemberg is another one,who runs that Italian tech website.
I don't think it was ever going to be a perfect solution with Pascal in truth but it looks to be more than capable to me, at least on paper.
but it can't truly execute lots of concurrent queues.This is really interesting that you say that. Somebody a while back said Pascal is more like GCN1.0 in Async abilities,and they have been unusually accurate on some of their predictions. They are correct again,WTF??
But at the same time GCN1.0 does not have a performance penalty,so if Nvidia is faster in other ways it should be OK.
I was reading the Arstechnica review and saw this statement:
http://arstechnica.com/gadgets/2016/05/nvidia-gtx-1080-review/2/
If the 1070 is around 980Ti/TitanX in performance as expected, then yea, it should be good enough for 1440p/60fps with High-Ultra settings. You wont be able to max everything out, but so long as you dont mind that, I imagine it'll be a really good card for your needs.Not sure which card to go for so asking fora little assitance in my decsion making. Currently I am running 2x 670's in SLI with a resolution of 2560x1440 (Dell Gsync).
Been holding out for an upgrae for a while now, nearly pulled the trigger on a 980Ti.
So for the rez I run at will a 1070 be enough? Or should I opt for the 1080 due to the extra horse power? Ultimately would love to play games at high/max details.
Thanks in advance
It obviously is, but more importantly - WHO PLAYS this damn game? Why are people so obsessed with how a card runs on this game that nobody actually cares about beyond its benchmark tool? It's just weird.But Ashes of the Singularity is CLEARLY an AMD biased game, that's why Nvidia cards performance suffer...or at least that's what I already see people preaching at this part of the forum when it comes to dx12 discussions![]()
If people want DX12 performance benches, then use games that people actually likely to play - Tomb Raider, Hitman, etc.
Simply because it's been built from the ground up to use DX12, most other titles as DX11 games with a retro fit added on to support DX12. It's the only title out there that gives us an idea of what to expect once DX12 gains more traction.
Only in a very equivalent fashion - the implementation isn't anything like GCN 1.0 but there is some equivalency in what it effectively brings to the table.
The interesting thing is that with Polaris AMD have actually gone a bit towards the nVidia approach while they are still using the GCN architecture the ACEs and scheduling hardware appears to have been rejigged to finally face the fact that developers don't tend to implement workload in the idealistic broadly parallel way and better able to balance performance between broad and narrower workloads.
They said the block with be compatible with cards with reference design board/PCB, which is just stating the obvious. What I was referring to are cards with non-reference design board.
I reckon we'll see a Titan X Pascal equivalent release first before the GTX 1080 Ti
With a masssssive premium.
Indeed, got to make the Ti look like a bargin.
For those with a limited budget,yes, but there's only one top-end card each generation and it come at a premium but still worth it if you have the £ or need it for the resolution you play at.
The definition of A bargain is perceived value whether you can afford it or not, being able to afford it or not does not change something being a bargain or not.
Indeed, got to make the Ti look like a bargain.
