This is why the Aprilia got the 2006 Masterbike award, buts thats another story
However in terms of power, the RSV isnt lacking in that compared to any of the big litre jap bikes, the torque is pretty much comparable for the most part just with a lower BHP.
But again most people compare the power of the new litre bikes against the power of the older Mille when comparing the two types of bikes, totally wrong, the new RSVR is a totally different bike altogether.
A lot happier to rev higher than before and quite happily hitting 180mph if needed, but the low down grunt is more than a match for any other litre bike.
A friend of mine is currently leading the table in the New Era Sound of Thunder championships and is running an RSV Factory that is putting out 170bhp at the crank and its more controllable than any of the other bikes on the circuit due to the way it delivers the power and that thing had have the gearing changed because it was hitting nearly 190mph on the Revvitt straight at Snetterton
The only real difference between all the new bikes is the character, they will all pretty much do what they were designed to do from a track perspective, some behave better on the road than others, but unfortunately most riders arent actually capable of riding the bikes on the road well enough to understand where the weaknesses and strengths of each lie.
Dont get me wrong, i have a soft spot for the K61000 and very probably the K5 too, the earlier ones are only in the same league in terms of engine performance, the rest is totally different in terms of handling and looks,
Ultimately though they are "belly button" bikes, as in "everyones's got them"
(that was a joke by the way, dont want the riceracers getting upset
