Sweet, another thread. Question to the OP. Do other reference cards throttle? Do non ref cards throttle? What was the fan curve? What fan speeds were they throttling at?
In all my time using reference cards, they have all throttled, so just wondering why this is something a lot of people are worrying about?
"Stays cool and can be overclocked easily to over 2ghz".
Is this not a lie? Was AMD not slated for this when they said "an overclockers dream"?
Why is it different with nvidia?
I actually detest the cooler on my TX. The ref cooler is noisy and doesn't do a great job but if you look at that video I did earlier, I show what is what and that is within a minute of the bench running (clocking down).
Thread title should be changed to "NEWSFLASH: GPU Boost works as expected".
While I agree with you on the technical side of things (most ref cards throttling) it's a bit different when it's the only version available and at a price premium because then it's a matter of the emphasis those setbacks place on the entire set of currently available cards. If it wasn't the only option and going to cost you a premium for the convenience of the throttling then I could agree it's not an issue.Sweet, another thread. Question to the OP. Do other reference cards throttle? Do non ref cards throttle? What was the fan curve? What fan speeds were they throttling at?
Agreed, some just need it day 1 if they are making a build right then so it can be situational but it's just one of those things. I'd be waiting for a none ref cooler but peoples choices are there's and hopefully they did there homework as you said.I feel most of us here have done our homework (if not bloody get on with it) and seen that the extra $100 for the FE is a bit of **** take, considering that the 8 pin is enough for this and that but not enough for any overclocking fun, the cooler does a good enough job but if it is like the TX cooler, will be fairly noisy when it is ramping up (and looks like it will need to ramp up to keep the card cool). For those uninterested in overclocking and will be watercooling and must have the card on day 1, go for it![]()
I'd get the cheapest card from the non FE editions and stick a block on it or attach an AIO.
You must not be pc gaming very long if that's the case![]()
