You the real MVP. What position in queue are you for the classified?
27
Ive run SFF cases for a few years but have stuck with open coolers even though the hot air is being dumped into the case. Firstly they get a little help from being next to the case side which often has many holes. Also with recent CPUs I think CPU cooling is not such a problem for gaming - maybe a rad system isn't needed just a decent sized heatsink and quiet fan. On my current Fractal 500 I just have a rear exhaust which seems to do a good job of pulling the heat out the case but I do have to watch the power target on the GPU - so Pascal will be a good benefit.
Same for me. I am building a new X99 system Saturday based around the 6850K chip and my last build was custom water but not anymore. It is a chore to fill and empty and swap bits out. Massive benefits to water but i will be going just AIO for the CPU this time. I don't oc for games either.
just found out the KFA2 1080 EX OC isnt due in stock till the 26th! eeek. Oh well.
Might aswell pay more and go for the EVGA SC
All the FE cards sold out again, some people are getting withdrawal symptoms waiting on the third party cards.![]()
Have the same issue, using a 780Ti still and the 1080 is very tempting. Trying to hold out for the Ti next year.
Saying that I'm impressed with how well the 780Ti still holds up, those extra frames though...
But tbh it's pretty epic, much quieter than expected
I bought oneBut tbh it's pretty epic, much quieter than expected
Well customer support believes that the Xtreme will come in on the 17th. I hope that's correct because I'm dying to play some new games.
They also said that I can call for a refund on the postage as it should be free for all 1080's but someone forgot for the classy and hybrid
If you want the classified I'd preorder now, EVGA hasn't officially priced it yet and it could go higher as well. I think OcUK is listing 1080s by the least preordered if you search for it (not confirmed) - at least the Classy and Hybrid are among the top 3 and are the lowest known queue according to this thread, with FTW appearing near the bottom of the search and the highest queue. Might help you get one faster if you're choosing between a few.Do you know what is your queue postion on Xtreme card ?
