I would imagine theoretically possible, but the effort involved would make it extremely unlikely purely to get someone for a doing a little bit over the limit on the motorway
"80ish" indicated would be around 72-5 actual speed
wouldn't that involve finding the exact place where the OP was driving, and then measure the distance between those 2 objects exactly parallel to the path the OP took (including lane changes etc)?
Then there's also the assumption that the camera has a high enough framerate to accurately measure the speed to within the tolerances required to prosecute.
As I said, it's probably technically possible given the right circumstances, but I would place money on it not being worthwhile just to give someone 3 points and £100 fine for being 10 miles over the limit on the motorway.
Lol yes you're right
Erm around 80'ish
I suppose they could take two static objects from your video, go out and measure the distance between them and then time how long it takes you to get from to the other. From that they could calculate a rough speed.
