The Pascal GTX 1080 Owners Thread
Waterblock has been shipped should be arriving tomorrow. Once fitted will see what overclock I can achieve and post my results.
Well the eta should be for what is available for ordering, not what has already been ordered.
For example if you had 3 batches due in 7th, 10th 17th with 50 cards per batch and 77 had been ordered you expect the site to show the 10th, if it had pre-sold 106 you expect it to show 17th.
(I don't know if this is the case, but it would make sense) :)
The FE is nice and quiet even when stressed. Temps get a bit high for my liking but I will take that over noise I guess.
The Hybrid EVGA card will be the one I keep until the full fat cards arrive. Low temps / noise and really like the design.
I have been getting this weird flickering with my 1080 I have done a quick video showing the problem has anyone else been getting this?
It seems to happen when gsync is enabled.
This never happened with my titan x.
Yup first thing I tried and another DP port on the card same issue.
Similar thing was happening to someone before. I believe re-seating the card sorted it. Either that or DDU and re-install drivers.
Like iron said drop the screen to 120hz for the desktop. 144hz has problems on the desktop. GPU doesn't downclock etc.
Noob question : Got my evga 1080 today. The power to Graphics, it only connects into 1 main plug so to speak into the PSU? I have obviously connecting the 2pins from GPU...
Only reason my graphics card randomly revs up and then calms down ? Is this normal / a common fault with the 1080? My room is a lot warmer now....
See this thread
https://forums.geforce.com/default/...1080-founder-issue-fan-issue-updated-6-2-16-/
The erratic fan behaviour is apparently fixable at a driver level according to nVida. The driver is due any time now so we will soon see
Both underwater running maxed out in the 30's. They can manage 2100mhz in SLI with memory clock at 11,000 (more testing tomorrow as havent upped the voltage yet). More than happy with this.
I'll give some benchies, pics and overall perf tomorrow. Time for bed now :).
