For the price difference vs what you're paying overall, the FTW is a much better choice.
Much better is very questionable. If they all overclock to the same level then you're really just talking about how loud a card is to achieve that.
Well if anything it would overclock a bit better, also bigger cooler and bigger fans = lower temps and less noise. So overall for an extra 30 its alright, but if it was 50-100 more then I agree it is not worth it.
If you're paying almost £600 anyway, buying an inferior card for the sake of saving £30 seems silly to me, because I value silence and a larger cooler will provide something closer to that. But hey, who can say how it'll pay off. Maybe you get a golden sample SC that overclocks ridiculously well. Maybe you change your order and get a crappy FTW that doesn't.
Doubful as previously mentioned 8pack said that there is a wall when it comes to the voltage as 1.25 seems to be the upper limit which aapears to be hardware level or driver or combination of both. So with that in consideration we might only see those magical cards that will go past 2.2 - 2.25 and stay there 24/7 for gaming.
For the HB bridges, we should have the 1.5 and 2 slot bridges around 20th June in the UK I would hope in time for the FTW.
This was the schedule we were working towards last week.
Ben
I am to push my SC to 2000 MHZ after a few months. Then sell it for the Titan next year. £30 can go far if you know how to save or spend.
Found out I'm 176th in the queue for an FTW, considering how late I ordered that's actually better than I thought.
Will hopefully be in the 3rd or 4th batch (beginning of July I'd imagine).
Does anybody think the queue positions are legitimate? I have gone from 131st to 77th in a couple of days.
It's a couple of pizza's or a curry.
The FTW will be quieter and have better resale value when you sell it for your Titan. No Brainer really.
Do you get non-return holidays? Wouldnt that be called emigrating?
you can buy one way, to book a one way later on.
eg business meetings not sure when you are to return.
Is a business meeting a holiday?
