Black Suppressor
this is a picture where i have now put the reservoir and gpu and psu into the case
and this is a picture with all fitiings in and the flow meter in place
so i did the first two parts. Found it a lot harder to get the pipes in place. Had to remove the gpu and install both pipes into the gpu and flow meter and then insert the gpu back in and plug in the tube into the cpu block.
next picture is of the next two parts to the loop. I found the part that goes from the cpu block to the radiator particularly difficult but a bit of perseverance and i managed to get i it in.
I Hope you have enjoyed so far.
Next up im going to build a full custom sleeved cable set for my psu. I will get that completed as soon as everything arrives. may be a little while because the parts are coming from china but are flying now so hopefully less than a week.
Stay tuned....
Looks good. Noctua colours are very Marmite so good to see if goes well with the copper theme.
The pipe from front rad to top is the only thing that looks a bit untidy and in the way. If you moved the cpu-to-top-rad pipe to the other port, could you then run the pipe from top rad like this?
90 degree bend straight up, 90 degree bend parallel with and tucked behind (or under) the rad and then bent to connect to the top rad.
Looking nice mate. Any thoughts of a buff of your pipes? :eek:
Getting them super shiney would really set off the effort you've made.
Thanks. Yeah I originally was going to do that but just found it really tight getting the pipe into the cpu. I am thinking about changing it around because where the flow meter is sitting on the psu it's making a high pitched noise. I think I'm going to have to drain and change that around. So I think I will alter all of that because I'm also going to fit a heatsink to the pump so I guess when I've got everything else finished I might change that pipe you are talking about too.
I'm not sure yet. I'm going to give it a while and see how it looks when the pipes all gone brown. Depends how that looks and then might end up doing that. Not sure what to put on the pipes once polished to keep them shiny. Any ideas?
If anyone's reading I thought I would ask a question. Do you think it would look good spraying the front panel border grill a black nickel and also the brackets at the back?
