- 31 Jul 2012
- Cheshire
very nice when i get this case i would like to do something like that as i wouldnt like the look of seeing all the wires at the back.
how did you do it?
Thanks. It was quite straight forwards really:
1. Cut (or order pre-cut) a piece of 1mm polystyrene / plasticard 440mm x 470mm
2. Mark out holes on sheet in alignment with the glass panel
3. Use a 12mm spade bit to drill 4 holes
4. Apply any artwork (I ordered and used metal based ROG stickers)
5. Dust / clean thoroughly
6. Line up polystyrene sheet and stick in place with black eletrical tape
