- 24 May 2012
Hi all,
After wanting a change from my Bandit 1200, even though it’s been almost faultless for nearly 4 years, I decided to have a look around.
Only wanted to spend a few grand really to scratch an itch so was looking at older Triples and some Z1000, decent ones for the years (03 ish) seemed to hover around £3000. Saw an ’03 Z1000, 17k miles, lots of custom bits and cans, union jack spray paint and £2700! It was a CAT D which explained the price.
I called the garage and asked why and all they could tell me was it was wrote off in the first few months of ownership, I bought it and hoped for the best
I did do my own HPI check on the bike and it was manufactured in March 03 and wrote off in April 03, part service history since then with some full services etc carried out.
Is there any way to find out why it was wrote off? I’ve had it for a couple of months now without anything feeling wrong, apart from swapping the reg/rec which was a bit useless, just curious really.
Cheers
Cheers
