Cheers boss
EDIT - actually, I am being blind. Where on there page? Can't find it.
With the free £50 in play bet, would you need to lay this bet as it is risk free and you get it back if you lose?
http://matchedbettingblog.com/ is more than adequate for most people who want to make reasonable money per motnh
Thanks. Always got myself a bit confused with the 365 offer and how my £50 in play was a SNR, but seeing the example on that page shows why and that I'm stupid![]()
Clicking a live link from a matched betting thread is unlikely to be the smartest move FWIW.
Thanks - I hadn't looked on their splash page.
1x2 is match result right?
I usually hit the inplays at HT, so tonight ( I say tonight, HT will be aboout 1:15 am tomorrow for me) is going to be a bit hectic. Betfred, 365, Coral and a Laddys to do.
Yes! My bad, let me edit and remove now.
What bet do you normally do on inplays? obviously depending on Score if it's 0-0 "unlikely" I may put the free bonus bet on either a draw or pens as they have higher win stake.
I wondered this about using links directly from YesBets. Can't they tell?
Cheers for the advice guys.
I just made my first mistake trying reloads for the first time. Placed £20 in-play on Del Potro v Wawrinka, somehow put the lay bet on twice, cashed out, choked for a few minutes and then the odds went out the window as Del Porto broke Wawrinka and won the 2nd set
I hung on hoping he would turn it around and the odds would drop but nope. Lost £20. To top it off I don't think I even qualified for the £10 free in-play bet during Federer/Evans.
I've also done the Coral bet £10 get £10 in-play for tonight's game and Paddypower £5 for every goal (Belgium), hopefully those go a bit better.![]()
