whats the best thing I can use to record it?
I'll throw one one youtube for you to look at if you want?
Just watch it while it runs.
Just after the beginning of the scene or halfway through theres tiny freezing once in a while.
While I haven't tried it, I think it's pretty easy to look at how existing cards were handling it and extrapolate where a 480 would be.Anyone tried MGS V on a 480 at 1440p? How did it play?
In case the power thread was TLDR I created a diagram of the issues with the reference PCB.
I'm not sure I'd use MGSV as representative of 'most games'. At least not modern games. It's something that runs at 60fps on consoles, dont forget. So hitting 1440p/60fps with it will be easier than it will most games that only run 30fps on consoles.Thanks. That seems to be the thought for a lot of games at 1440p with a 480. Turning down a few settings isn't really an issue for me as I only have as 60Hz monitor.
Great. I'll see what AMD comes up with today but it looks like it may have to go back to OCUK. Don't feel sorry for AMD (what were they thinking?), but do for OCUK.
Not sure what card I'll get as a replacement. #Annoyed
I'd be hesitant to use a 480 for 1440p if 60fps was a priority, speaking generally.
Ditto. It sounded great, but it's crashed multiple times on both of my PCs.I really wanted to like this card but due to the massive headache of getting games to run has killed my enthusiasm. Looking around I can see I am not alone either and I am genuinely gutted. I have requested to DSR it and I will sit this GPU out.
Another game that runs 60fps on consoles already....seeing a pattern?I run DOOM at high settings @ 1440p at over 60fps on a R9 290X with a 27" freesync monitor without any issues "just saying"
Getting some GPU down clocking in Planetary Annihilation, goes down as low as 500Mhz. Weird because games like Crysis 3 don't down-clock. Is there a way to stop down-clocking?
Another game that runs 60fps on consoles already....seeing a pattern?![]()
I did not say it like that at all.You say that like it's a bad thing.
So is it worth getting this card? Seems to be lot of issues but since I bought a free sync monitor I don't particularly want to go with NVIDIA.
Currently have 280x so haven't even used free sync.
