Wow that is quite poor! Both my FE solid at 2100mhz. One runs fine at 2139mhz.
But not even able to hold 1936mhz is quite shocking. I'd be tempted to return it if it can't even hold its own boost clock.
It has been returned already. The card is faulty, as it is not achieving the speed it should. I had always assumed that all cards are tested to run at whatever clock speed they are designed to run at. Obviously not.
