My very old 9600LEits just laying around my desk. I love those RED PCB
Will the WattMan software work with AIB cards?
Gonna replace the 970 in my other system with one of these AIBS
Will cost peanuts after selling the 970
Devil or Nitro? How are these coolers rated in past cards? (No Idea been with Nvidia since 6850)
There really isn't much of a difference between a 970 and rx 480 in most games, tbh. Not sure if a replacement would give you much gain.
Plan to play a lot of DX12 titles
TW Warhammer right now for example
The extra memory sounds good also
What resolution will you be using? I'd go for an 8GB version as this game uses a lot of video memory at maximum settings.
1080p 60hz right now.
Will upgrade to either 1080 144hz or 1440p 60hz with Freesync in a month or less.
So far I'm leaning towards 8GB Nitro.
At 1080P you might be okay with 4GB, but at 4K i was falling short.
4Gb failing short at 2560x1440 unfortunately also.
XCOM 2 been the culprit
Oc 1060 vs OC 480...
http://www.3dmark.com/compare/fs/9202637/fs/9188962#
If true, things don't look so good for the 1060, especially at the rumoured price
Has the fix for pcie slot power draw been released yet and if so has it dine the job?
