Ideally I would like to get it sorted now, not sure what returns policy is for ocuk because it's already been back to them 3weeks ago when it wouldn't display anything at all and was returned as no fault found.
Has worked the times I've used it in the past 3weeks but now is doing this on every dp output.
I will try reseating everything apart from the cpu. Indont have another monitor but did test with a 290 gpu and it didn't happen with that.. I have got an rma number again and will return it if reseating everything doesn't work.
Ignore me - it was an r9 380 that I used when this one was at rma.
Original fault was that I could not get this card to output anything at all but the 380 was working fine. However after the no fault found rma and a bag of haribo lol. I installed the 390 and it worked fine.
Has done for 3weeks albeit not for long periods and not a particularly demanding game (rust).
The suggestion above seems viable but I will need to remove the card to allow me to do the sweep of drivers.
And sorry for the noob questions but memtest what does this do and how do I do it ?
So memtest is to rule out my ram being at fault. I will try it all when I get home later.
Don't know if it makes a difference but when Windows on desktop the gpu is in silent mode with fans off. When it goes pixelated and then blanks it out the fans come off and on. And the card is hot to the touch.
