Caporegime
- 18 Oct 2002
Don't mind man, you tell me and I'm on
Im up for it Gamble - what time?
It's sad that the community devs had death threats "and worse" on reddit PM following the G36 thing.
DN: up for it of you need a fourth to help out. If not there's plenty people still needing to run it. So wouldn't mind doing what did with CS; rotating people through it. So in short, if there's space there's space, and if there's not there's not.
Mic sensitivity in discord made no difference, couldn't find it in Windows, will look further into it. I fear the headset is busted.
right click on volume icon in taskbar, go to recording devices.
Then select your headset and go to properties, then levels.
Top slider is for the microphone. You can also test the mic via this.
What about FL? Sentrys ftw
what an absolute joke....
Mic sensitivity in discord made no difference, couldn't find it in Windows, will look further into it. I fear the headset is busted. Or maybe it's the discord region setting.
I'm assuming you don't have an additional mic knocking about or you'd have ruled the mic itself out. You can plug headphones into the mic port to see if you get any noises going into Windows.
Hey Twirls, have added you. Can run Tactician or Reclaimer w/40k skill
Need to get some DN runs in!!![]()
No second, and headset is USB
really? that's terrible, its only a game at the end of the day!
yeah was watching the twitch feed over lunch and apparently after hamish posted the confirm of the G36 stealth nerfs other than the 400 downvotes he got messages about going to "F himself", or "go die", "or worse" (wouldn't say what on stream).
sometimes i weep for the internet.![]()
wasn't his fault ffs as he didn't even know! He had to go investigate to get confirmation it was a legit change
Idiot children on the internet neither know or care about important details such as this though![]()
Nope, this doesn't even begin to excuse such behaviour. Game needs a lot of re-balancing, people best get used to change.Shows how ****ed off people are getting with the nerfs though for poor Hamish to get such abuse!!!![]()
