*** The Division Thread 2.0 ***
Im up for it Gamble - what time?
Don't know yet to be honest. I said 6pm last night but was later due to work, so wont set a time for the time being.
Will just come online and see what happens, or post on here like 10/15 mins before I come online or something.
DN: up for it if you need a fourth to help out. If not there's plenty people still needing to run it. Or wouldn't mind doing what we did with CS; rotating people through it. So in short, if there's space there's space, and if there's not there's not.
Mic sensitivity in discord made no difference, couldn't find it in Windows, will look further into it. I fear the headset is busted. Or maybe it's the discord region setting.
DN: up for it of you need a fourth to help out. If not there's plenty people still needing to run it. So wouldn't mind doing what did with CS; rotating people through it. So in short, if there's space there's space, and if there's not there's not.
right click on volume icon in taskbar, go to recording devices.
Then select your headset and go to properties, then levels.
Top slider is for the microphone. You can also test the mic via this.
What about FL? Sentrys ftw
Thanks for the tip! Yeah FL too. Of course! Typed a whole post, accidentally pressed previous thread, swore and tried my best to retype it via the auto predict lol can we run Tek through it as well for his sought after gloves?
I'm assuming you don't have an additional mic knocking about or you'd have ruled the mic itself out. You can plug headphones into the mic port to see if you get any noises going into Windows.
really? that's terrible, its only a game at the end of the day!
yeah was watching the twitch feed over lunch and apparently after hamish posted the confirm of the G36 stealth nerfs other than the 400 downvotes he got messages about going to "F himself", or "go die", "or worse" (wouldn't say what on stream).
sometimes i weep for the internet. :rolleyes:
wasn't his fault ffs as he didn't even know! He had to go investigate to get confirmation it was a legit change
