Caporegime
- 18 Oct 2002
Yup, it's incoming now
:cries:
Supply drop received!! Only popped on to mess with my kit for 10 mins
Says to get it from the Rewards Vendor![]()
haha, reclaimer is definitely a worthwhole person to have though, makes the bosses so much easier as explosive rounds stop them shooting flames etc.
twirlyPS We need more characters now. Can't juggle between 6 "usable" builds and frontlines is still yet to come.
Is the supply drop supposed to appear on the map?
Chefie - Thanks for the invite but I was only on to get the Supply Drop, can't be bothered actually playing it for a prolonged amount of time at the minute.
I will be running DN and FL tonight as I need more sentrys pieces/reclaimer/deadeye/reclaimer. Just to save or my alt so I can try some different builds.
No worries Flash. Hope to see you and Prattler back on at some point![]()
<Read As> Not allowed.
I would really appreciate a FL run. I'm having no luck obtaining sentry gear via any other method. I tried grouping with randoms night and it was about as much fun as having teeth pulled. I don't have a Mic, which may be a slight hindrance. However I do have a good build and good gear, so yeah, take pity etc![]()
It is literally no hindrance at all having 1 without a mic. Even two is ok, as long as you can hear.
