- 24 Mar 2011
- Kent
Are you carrying a pillion?
If not, then the only choice is Kreiga
If not, then the only choice is Kreiga![]()
Are you camping? If not you'll get away with a 20 and 2x 10's, or a single 30. The 30 is big so is a tight fit on some seats, but if you're camping for 10 days you'll probably need to space.
Don't forget to use the 44teeth rewards page for 10% off.
