Pascal Titan-X Launch
LMFAO I can say the same thing about you not listening.
GDDR5X is on the 1080/1070 and that VRAM has been doubled. Explain why the have doubled the VRAM on these cards and not the Titan? Its irrelevant as these cards have doubled in VRAM if they had stayed the same I might see your point but this is not the case.
If you don't buy into the theory then fine that's your prerogative.
They doubled partly to match the 8gb on the AMD cards , atm there isnt any real need for more than 12gb, Cant really double vram every new gen or give it a few gens and we will see 40gb+ gpus :O
1070 has conventional GDDR5 IC
You asked when a top line card ever released with the same amount of memory as the previous top line card. I answered it. You are now trying to use some super lame excuse to dismiss the fact that you thought you had a point and totally didn't.
Are you not listening to anything I'm saying? Why do you just keep repeating this over and over?
It is NEW and BETTER memory. You do not need to add more of it to get a big jump in memory capability. 12GB of GDDR5 is not = 12GB of GDDR5X no matter how much you try and ignore this super relevant fact.
488GB/s man.
Also you are incorrect about the Titan having a crippled core count. Same amount as GP100.
The titan is indeed a crippled card meaning that it should have 3840 cuda cores I sense a repeat of Kepler why they have no competition just like the original titan
if its only going to be 25-30% faster than the 1080 - i don't see where a 1080 TI fits because you can make 5-10% up with a decent overclock on the 1080.
Discounting the crap cards, eventual Pascal line up will be:
Mid End
1060 £250+
High End
1070 £400+
1080 £600+
Ultra End
1080Ti £900+???
TXP £1200+???
Here was me thinking I was mugged off for my 1070, good news however after my OcUK brainwashing sessions have convinced me it was actually steal.:p
Because the 970 and 980 were not already saddled with an overkill amount of vRAM. Also the 1070 does not have GDDR5X.
But according to you if you put GDDR5X on a gpu you dont need to up the VRAM.
The Titan is all about an overkill of ram and for $200 more than the last Titan you would expect it to be raised some what. If you dont then thats fine but I for one do.
As I said we will see once the whole stack of the 10 series is released as to how this will play out. ;)
When I game I use the 12gb TXs as they are the best for it.
I also have
1080s
1070
1060
980 Ti's
980s
Fury Xs
290Xs
And quite a few more I can not be bothered to list.
The point is I am not short of memory options or cards for gaming. Some of the cards above individually are actually faster than the TXs but none of them are as good for gaming at high resolution.
There is nothing pointless about the 12gb memory on the TXs, it is their best feature.
Why do you have so manyh GPU's ? you got 10 kids? lol
There will be a Ti - What do you think they will do with the failed chips?
I said "at least not until AMD's Vega", if there using failed chips they will also be slower.
Also, these very well could already be failed Workstation chips.
Not if you already had 12GB of it before, no.
12GB of 10Ghz GDDR5X on a 384-bit bus *is* overkill.
It's not 16GB of HBM2 overkill, but still overkill nonetheless.
I would expect to see 16gb and not to double it the VRAM on the Titan.
True.
So which is it you want to know why its not doubled in one post then in another say you dont expect it.
Titans havent always had Vram jumps,, original titan was 6gb titan black was.. 6gb.
There is no point putting more ram on if its not needed
