Needing all those volts to "break through" the 6% OC "barrier"...![]()
So in the eteknix review, the fans were spinning really, really fast and under load it was 75 degrees. So with the fans down to sensible levels, it's going to be how warm I wonder? It peaks at 300W under load so it sounds like it's going to either run hot, or it's going to be loud.
Do not want.
During idle states, the graphics card’s 0dB fan mode comes into operation and allows for silent running providing other components emit very little noise. This an excellent addition and ensures the system noise remains as low as possible when viewing online content, and other basic tasks. Annoyingly, a driver bug prevented me from accurately assessing the load noise output which is the reason why there’s no data being displayed below. AMD’s latest driver automatically overrides Sapphire’s tuned fan profile which results in ridiculously fast fan speeds above 2300RPM. Apparently, it’s because AMD targeted a 65C delta instead of 75C which the Sapphire model’s cooling apparatus is based upon.
Just dropped in a pre order for this cardHoping this isn't too off topic but I currently have an i5 3570k (running at 4.3ghz from 3.4ghz stock) with 24gb of ddr3 at 1600mhz. I'm guessing this cpu won't be causing any major bottlenecks for a 480?
Ah, I was confused by this "When stressed, the graphics card consumes just over 300 watts". But I see the graph is titled "Total System Power". Still, I want to see some proper noise and thermal tests of this card. Gamers Nexus do good thermal testing, giving the value as a delta away from ambient temperature. I'm simply not buying another AMD card that hits 90+ degrees. I want to buy an AMD card again, but I can't put up with the thermal throttling.
Mmm yeah, ask around here what people think of XFX cards.Not my XFX. The marketing claims it's cool and quiet, but it's just the opposite! Changing the TIM on it this weekend to see if it helps.
The 480 should only use about 160-190W depending on overclock.
So are you saying that the 1060 gaming x uses only 60-90w.? Because on their graph its pulling exactly 100w less than the RX 480 nitro+
AMD really haven't made as big a leap in perf per watt as i thought they would. 100watts more at full load compared to the 1060 gaming x!
10 degrees hotter as well but then the gaming x is a very very good cooler.
