I just buy good quality ones with product in from a supermarket, empty the stuff and use thoseI need some decent quality spray bottles to put insect and tar remover in. The bottles the Autoglym stuff comes in are garbage.
Can anyone recommend any that are fairly cheap?
Oh, where did you get your lance from on offer? I have a Nilfisk C140 and I'd quite like a lance for it.
Edit: Oops, I was too late and Armageus had already responded!
The latest version of the C110 (and likely other Nilfisks) uses the Nilfisk Gerni connector (as opposed to the more common Nilfisk Alto)
I have this Snow foam lance with my C110, which works well:
https://www.amazon.co.uk/gp/product/B00O9XPX1A/
The foam bottle it comes with is a waste of time - it doesn't produce any actual foam.
Also with your C110, you may want to order the Auto nozzle (if you haven't already - as it didn't come with any of the different C110s when I bought mine):
https://www.amazon.co.uk/Nilfisk-6411136-Auto-Nozzle/dp/B0001P0BR6
I just buy good quality ones with product in from a supermarket, empty the stuff and use those![]()
I have one of these - http://www.ebay.co.uk/itm/Nilfisk-A...076008?hash=item25a3b0ffe8:g:hwUAAOSwn8FXRwXX
Seems good to me![]()
Cheers, is the auto nozzle essential then - not seen it mentioned before around the car forums and the c110 seems universally used!?
My audi dealer offers to wash my car every Saturday for the lifetime of my ownership![]()
That's the wrong fitting for the C110 (or at least the new ones)
The auto nozzle has a wider slightly lower pressure spray to avoid damaging paintwork. One of the nozzles the c110 comes with is definitely unsuitable for cars - the other you could probably manage with if you are careful.
Really? I've always used the nozzles my 110 came with and had no issues.
Spec me a splattered bug remover... I'm doing more long distance trips now - averaged 300 miles a weekend in the past few months, impressive for a full time PhD student (with no real chance to wash car in between) so I'm committing mass genocide all over my bumper and mirrors and they are getting baked on. I would simply clay it but I don't feel like claying my car every fortnight (RIP claybar) so something I could throw in the boot along with a MF cloth would be ideal.
If there is nothing 'reasonably' priced then I guess I'll suck it up and clay it more.
