Toothpaste first followed by hairspray.......
Varying grades of wet dry paper and then mix some sealant with some meths and apply a few thin coats. Problem solved. Have a google of the Hellman Spar method, has more details. Sod the expensive kits![]()
Not all toothpastes are abrasive. Find the right one and they'll look mint.Toothpaste never worked for me...
That's impressive!
What grades/compound did you use? Did you seal them afterwards?
How long did it stay like that though?
I'm going to go down the 1500 grit, 2000 grit and Meguiars PlastX route when I do mine. I've read a number of posts about a good end result.
I'm just not sure what to seal with afterwards? Will normal car body wax (Collinite 476S) do the job? I know 3M do some decent UV protection products.
