Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
It's only been 6months since I did it last, would the following be acceptable?
Foam
Wash
Clay
Wax
I can do the above fairly quickly, polish on top would take twice the time. If it needs done I'll do it but I'd rather avoid if possible?
I just did that, it depends how much swirl your paint has, if it's half decent and you are careful with your washing then you don't really need it.
I would advise to rinse after clay, then towel dry. Just to remove the last of the dirt that the claying has lifted but some reason didn't pick up.
