The Pascal GTX 1070 Owners Thread
Thoughts on the EVGA cards guys? Particularly the sc gaming and the ftw models
Thank you.
Ps I hear EVGA have excellent after sales support,and are based in the uk? That true.
Cheers
I don't know really. I just tested this. Fired up heaven looping and my amp extreme goes to 2037mhz straight away then to 2025, then settles down to 2012mhz. It will probably go to 2000mhz eventually.
Max reading for TDP and voltage in gpuz however is only 68.1% with 1.0620v on the volts.TDP mostly around the 60-65% mark. Temps settle to ~60 degrees whilst looping.
I think it just how they work ( this is all at stock/out of the box by the way)
The boost is very variable on what is going on. For example playing Arkham Knight with vsync on at 60fps it never boosts. Just stays at the base clock of 1632 MHz because gpu usage is only around 50% most of the time.
yeah as I concluded earlier in the thread, the zotac amp extreme's have a much higher TDP limit, but most 1070s have a much lower TDP limit than the zotac's.
Sadly my comments on this seem to have got very little attention (both on here and other sites), but the few people who I have discussed with have also discovered different cards even from the same vendor have different TDP limits, e.g. a palit jetstream has a lower TDP limit in the bios than the gamerock premium. Also that the zotac (non extreme model) has a lower TDP limit than the extreme but still higher than palit.
I did play with the curve in msi afterburner on my card and surprisingly it is stable at 1.06v at 2140 clock speed but I wont run it like that for gaming, just did it for a test. The card cannot sustain higher than 1.06v at high load due to the TDP limit, it is what it is. These cards are sold as power efficient cards hence the aggressive TDP limits.
This arrived last week!
Currently running +165 core +450 mem, stock power, stock fan profile. Sits low 60s in game.
Though i get an error message in Firestorm when i start it, saying power target cannot be 0!
Any ideas ?
Welcome and on TROH.:)
The Roll of Honour.
Date 01/08/2016, Make Zotac AMP Extreme Edition, Rom, Link
Date 30/07/2016, Make Inno3D Founders Edition, MOOGLEYS, Link
Date 30/07/2016, Make Palit Jetstream, Ogi, Link
Date 30/07/2016, Make Zotac AMP Extreme Edition, NinjaCool, Link
Date 29/07/2016, Make Palit Dual Fan, Bishie, Link
Date 29/07/2016, Make Palit Dual Fan, heatonpkmassive, Link
Date 28/07/2016, Make Zotac Founders Edition, _Jimlad_, Link
Date 27/07/2016, Make MSI Gaming X, Ex3cut3r, Link
Date 23/07/2016, Make EVGA FTW, Aretak, Link
Date 23/07/2016, Make Zotac AMP Extreme Edition, Defiant306, Link
Date 22/07/2016, Make Zotac AMP Extreme Edition, C6ckneyGeezer, Link
Date 22/07/2016, Make Zotac AMP Extreme Edition, Bickaxe, Link
Date 22/07/2016, Make KFA2 EXOC, MeatLoaf, Link
Date 22/07/2016, Make Palit Super Jetstream, Troop, Link
Date 22/07/2016, Make Asus Founders Edition, ah9098, Link
Date 22/07/2016, Make EVGA Founders Edition, Kaapstad, Link
Date 21/07/2016, Make EVGA FTW, clone, Link
Date 21/07/2016, Make MSI Gaming X, Gripen90, Link
Date 19/07/2016, Make Zotac AMP Extreme Edition, XeNoNF50, Link
Date 15/07/2016, Make KFA2 HOF, Solidair, Link
Date 18/07/2016, Make MSI Gaming X, Amatsubu, Link
Date 18/07/2016, Make Zotac AMP Extreme Edition, Jono8, Link
Date 16/07/2016, Make Palit GameRock Edition, Raikiri, Link
Date 16/07/2016, Make Gigabyte G1 Gaming, foster grant, Link
Date 16/07/2016, Make Zotac AMP Extreme Edition, tommybhoy, Link
Date 16/07/2016, Make Zotac AMP Extreme Edition, TNA, Link
Date 15/07/2016, Make KFA2 EXOC, Darren_uk, Link
Date 14/07/2016, Make MSI Gaming X, Troezar, Link
Date 14/07/2016, Make Zotac AMP Edition, Mario, Link
Date 13/07/2016, Make Zotac AMP Extreme Edition, MarkeR, Link
Date 13/07/2016, Make Gigabyte G1 Gaming, foster grant, Link
Date 10/07/2016, Make Gigabyte Windforce 2x, wellibob, Link
Date 10/07/2016, Make Gainward Phoenix Golden Sample, roddypoddy, Link
Date 08/07/2016, Make Palit GameRock Premier Edition, chrcoluk, Link
Date 08/07/2016, Make Palit GameRock Premier Edition, JTrickle, Link
Date 08/07/2016, Make Zotac AMP Edition, gtw1212, Link
Date 07/07/2016, Make MSI Gaming X, magicoi, Link
Date 06/07/2016, Make MSI Aero OC Edition, Amatyr, Link
Date 06/07/2016, Make MSI Gaming X, divinebeetle, Link
Date 04/07/2016, Make MSI Gaming X, i_am_jon, Link
Date 04/07/2016, Make Palit GameRock Premier Edition, Phil87, Link
Date 03/07/2016, Make MSI Gaming X, V_R, Link
Date 03/07/2016, Make Palit GameRock Premier Edition, foxyfaefife, Link
Date 03/07/2016, Make MSI Armor OC Edition, chris-82, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, razorpakk, Link
Date 02/07/2016, Make Palit GameRock Premier Edition, styuR, Link
Date 02/07/2016, Make MSI Armor OC Edition, Shawreyboy, Link
Date 02/07/2016, Make Gigabyte G1 Gaming, Gripen90, Link
Date 01/07/2016, Make Gainward Phoenix Golden Sample, shrek2, Link
Date 01/07/2016, Make NVidia Founders Edition, BornEvil, Link
Date 30/06/2016, Make Gainward Phoenix Golden Sample, thefogo, Link
Date 30/06/2016, Make MSI Gaming X, Carta, Link
Date 29/06/2016, Make Zotac AMP Edition, Charlatan, Link
Date 29/06/2016, Make MSI Gaming X, Daaaveee, Link
Date 29/06/2016, Make MSI Gaming X, Aretak, Link
Date 29/06/2016, Make Inno3D iChiLL X3 Edition, leerogers00, Link
Date 28/06/2016, Make MSI Gaming X, DougF1, Link
Date 28/06/2016, Make MSI Armor OC Edition, markoboyo11, Link
Date 27/06/2016, Make Zotac AMP Edition, Mangochutney, Link
Date 25/06/2016, Make MSI Armor OC Edition, BornEvil, Link
Date 23/06/2016, Make MSI Aero OC Edition, McGraw, Link
Date 22/06/2016, Make MSI Armor OC Edition, smithy83, Link
Date 21/06/2016, Make MSI Armor OC Edition, Phixsator, Link
Date 20/06/2016, Make Palit Founders Edition, Paul_cz, Link
Date 20/06/2016, Make NVidia Founders Edition, Dave2150, Link
Date 20/06/2016, Make MSI Gaming X, AthlonXP1800, Link
Date 20/06/2016, Make Gigabyte G1 Gaming, w00dy85, Link
Date 19/06/2016, Make MSI Gaming X, kully1972, Link
Date 18/06/2016, Make MSI Gaming X, AliGoz, Link
Date 17/06/2016, Make MSI Gaming X, philo-sofa, Link
Date 16/06/2016, Make Palit Founders Edition, Biffa, Link
Date 16/06/2016, Make EVGA Founders Edition, Daaaveee, Link
Date 14/06/2016, Make EVGA Founders Edition, mankycrack, Link
Date 13/06/2016, Make NVidia Founders Edition, !bluetonic!, Link
Date 12/06/2016, Make MSI Founders Edition, yoyo59, Link
Date 11/06/2016, Make MSI Founders Edition, JamesM, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1070.​
I'm curious how well the cards can hold upto higher current levels - haven't really had a chance to look into it.
Hmm I am about to choose between MSI gaming X and Zotac, I like the 5y warranty but WHY IS IT YELLOW JEEEEEZ....I got gaming 5 red MSI mobo.... color<warranty or color>warranty ?
I think this will be the card I'll go for. I'm 98% sure it'll fit in my Lian-Li mid tower but I'll have to double check the depth. So glad the power connectors are on the side. Hated AMD put them on the front side facing the front of the case on the 5870's. They say it is the fastest of the 1070's. I've been going through so many reviews checking everything out.
This'll be my first NVIDIA since 2006, 7800GS+.
It looks beetchin!
I .... almost .... caved in this evening after waiting for a 1060 or 480 I actually liked to come into stock. Saw a 1070 for $392 (dollars) and was closed close to pressing 'pay' after putting my details in lol. It was only an Asus 'DUAL' model, so no back plate, but had a reasonable simple white shroud that would go nice with my case, but too be honest I wouldn't see that with it facing bottom lol.
Well I hope I just became an owner.... I caved when I saw an ASUS ROG Strix GeForce GTX 1070 8GB Gaming Card for $383 (dollars). Fairly decent card for what is at present a good price.
This is the fastest and most expensive card I have ever bought. Should hopefully do me for quite a few years.
Reality is, I just got fed up of waiting for a custom 480 or custom 1060 I wanted.
Quick question....
Running a Palit GTX Dual 1070 here. Should the fans drop to zero ?
The min speed they ever get to is 1000rpm.
Do I need to use the thundermaster utility to manually override the fan settings, or should it do it out of the box ?
*EDIT* Just installed the thundermaster utility - the minimum fan setting appears to be 32% which is about 1000 rpm - hmmm ?
Ok narrowed down my search ... looking at the asus strix oc or the msi gaming x. Both have silent play and cool really good. And dont spin up loud.
Seems most go with the msi but I have a strix 970 here and I really like it; pretty much silent.
I had a Strix 970 and my MSI 1070 is significantly quieter. I could hear the Asus at load, whereas this is virtually inaudible.
Don't know about the 1070 Strix though but I went with MSI anyways because I hate triple fan designs. Pointlessly big and completely unnecessary in terms of cooling performance. Also, didn't want to pay the Asus tax.
