Quick question, people. I notice there is a Jetstream and a Super Jetstream version of the Palit card (the latter with higher clocks) Is it likely the standard one will clock to the same sort of level as the Super?
I've gotten the Palit Gamerock (non-OC version) stable at 2100mhz core clock (no throttling, temps stayed at an amazing 60-64c under full load 60%~ fan speed), memory would cause artifacting if above +460mhz though.
Should give you a good idea, someone correct me if i'm wrong but i'm pretty sure Gamerock and Jetstream are identical minus the cooler aesthetic (same heatsinks afaik).
