Dirt Rally Benchmark
Status
Not open for further replies.
Caporegime
OP
12 Jul 2007
United Kingdom
Run @ 1440p
CPU = 5930K @ stock
GPU = Fury X @ stock
Windows 10 Driver =15.20-150715a-184226E
Here's my result with the following
4790k @ 4.5
Fury pro @ 1140/550
16.7.3 drivers
1080p
Scoreboard updated. :)
18 Oct 2002
Devon
Thought it would be interesting to see how my trusty 780Ti fares, not too shabbily as it happens.
2700K @ 4.7GHz
780Ti 1276 Core / 3856 Mem
Latest drivers (378.49)
1080p = 92.06
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Benchmark Mode Results -->
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Paul" date="13:48:51 on 28/01/2017" machine="Upstairs">
<totals races="1" total_time="00:03:25" total_race_time="00:03:25" race_time="00:03:25" />
<fps_race min_fps="76.656586" max_fps="121.945679" av_fps="92.057594" min_fps_ms="13.045194" max_fps_ms="8.200373" av_fps_ms="10.862765" />
<fps_total min_fps="76.656586" max_fps="121.945679" av_fps="92.057594" min_fps_ms="13.045194" max_fps_ms="8.200373" av_fps_ms="10.862765" />
<track index="1" numInRotation="1" totalProfiled="1">
<results samples="18908" min_fps="76.656586" max_fps="121.945679" av_fps="92.057594" min_fps_ms="13.045194" max_fps_ms="8.200373" av_fps_ms="10.862765" battery_percentage_used="0" />
<settings name="hafren_rally_01" route="route_2">
<car name="555" livery="17" />
</settings>
</track>
<hardware_settings_config version="11" deviceId="0x100A">
<cpu>
<threadStrategy workerMapFile="system/workerMap4Core.xml" forceFeedbackProcessor="3" dvdStorageProcessor="3" dataSetMonitorProcessor="1" renderProcessor="0" updateProcessor="2" fileStreamProcessor="3" />
</cpu>
<audio_card>
<dynamic_range value="high" />
<eq value="flat" />
<voice_chat enabled="true" />
<push_to_talk enabled="true" />
</audio_card>
<graphics_card rating="4" firstBoot="true">
<directx forcedx10="false" />
<eyefinity force="" osd="" />
<stereo enabled="false" separation="0.015" convergence="0.5" />
<resolution width="1920" height="1080" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
<refreshRate rate="59" />
</resolution>
<gamma level="0.8" />
</graphics_card>
<shadows enabled="true" size="3072" maskQuality="2" particles="true" />
<advanced_fog enabled="true" />
<particles enabled="true" wind="true" dynamicRes="false" lowResScalar="2" nearFadeBias="0" />
<weather quality="1" />
<crowd enabled="true" detail="4" />
<cloth enabled="true" tessellation="true" />
<groundcover mode="ultra" clutter="true" />
<objects lod="1.02" maxlod="0" stones="true" />
<trees lod="1.2" maxlod="0" meshes="true" meshes_in_all_passes="false" />
<vehicles characterQuality="4" lodQuality="3" />
<track lod="1.0" />
<envmap faces="6" size="1024" drawallobjects="true" scaleminsize="0.75" mindistance="150.0" />
<water update="true" detail="3" scale="2" drawallobjects="true" tessellation="true" />
<mirrors enabled="true" width="768" height="256" car_maxlod="1" car_culldist="300.0" />
<skidmarks enabled="true" />
<dynamic_ambient_occ enabled="true" quality="4" />
<dynamic_ambient_occ_soft enabled="true" />
<night_lighting volumes="true" lights="0" shadows="true" onlyHeadlights="false" shadowSize="2048" />
<textures resolution="3" />
<shaders quality="2" low_quality="false" />
<anisotropic min="4" max="16" />
<physics environmentalDamage="true" vehicleDamage="true" />
<input device_type="auto" />
<screenshotMode enabled="false" />
<aoit enabled="false" />
<avsm enabled="true" />
<mouse_support enabled="false" />
<oculus enabled="true" headMovement="true" chromatic="true" timeWarp="true" vignette="true" overdrive="true" convergence="1.0" verticalOrientation="0.66" orientationLock="false" />
<motion_platform>
<dbox enabled="true" />
<udp enabled="false" extradata="0" ip="127.0.0.1" port="20777" delay="1" />
<fanatec enabled="true" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
</motion_platform>
<controls neutralTimeToShift="0.25" />
</hardware_settings_config>
</benchmark>
1440p = 65.28
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Paul" date="14:04:28 on 28/01/2017" machine="Upstairs">
<fps_race min_fps="54.934990" max_fps="83.037636" av_fps="65.289597" min_fps_ms="18.203335" max_fps_ms="12.042732" av_fps_ms="15.316376" />
<fps_total min_fps="54.934990" max_fps="83.037636" av_fps="65.289597" min_fps_ms="18.203335" max_fps_ms="12.042732" av_fps_ms="15.316376" />
<results samples="13409" min_fps="54.934990" max_fps="83.037636" av_fps="65.289597" min_fps_ms="18.203335" max_fps_ms="12.042732" av_fps_ms="15.316376" battery_percentage_used="0" />
</settings>
</track>
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
<resolution width="2560" height="1440" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
</resolution>
</graphics_card>
<track lod="1.0" />
<motion_platform>
</motion_platform>
</benchmark>
Permabanned
12 Sep 2013
Knowhere
Ah man, why did you have to bump this thread. :(
Sorry but I've got to bump it again as I had the settings wrong.
It's a shame they didn't do a bench for Dirt 4, but as they didn't Rally's the newest benchable in the series, Maybe you'll lose sight of it when Dirt 5 releases. :D
Seeing as the only 3440x1440 score is my Fury pro overclocked in the same rig we get to see how much of an improvement Vega offers for Ultrawide gamers.
Status
