- 27 Jan 2012
- The king of the north!
Good progress tonight finished 60% on the T4 Sheridan done 100% on the T5 Panzer
That thing is seriously OP compared to anything else i have been in always armed with the double weapon system setup can just keep pounding 1600 damage from the turret then change to the rockets (4 second swap time) then deal 700 damage with that then change back (4 more seconds) and put out another 1600 damage rinse and repeat. Seem to be between 9,000-13,000 damage per game in it consistently.
Also have managed to get the T6 Stingray up to 24%
I am mainly doing this line to get the XM8 up to 50% so i can get the Mk.3 Retrofits from it for when i get my chally 2 unlocked but want to push the retrofits first as i don't particularly enjoy these tanks other than the panzer so want to get them out of mind
Another thing you might want to keep an eye on is on the right hand side, about half way down is a button that shows you the 'daily challenges' - for the first one you complete in a day, you get 150k credits. Not at all to be sniffed at when some tanks cost 480k credits, although by later tiers it's a bit less effective. The next challenges get you crates, which can be awesome, or mediocre. Pot luck.
... worth it.
