That Uplay is a PITA. Glad you found it though.It was in uplay settings lol. Found it and turned it off.
Isn't there supposed to be access to the newer bios(s) in the devil club?
Our R&D team was being cautions about possible high RMA rates while use substantial higher Power limits.
As you might know, the power consumption increase is exponentially higher when it goes much above 1350Mhz and unlocked Power Limit.
(Warning! please use it carefully! ) https://drive.google.com/open?id=0B9HMk-E2fvNlQl84WjFBMmxtNEk
Ah hah!
A comment from Powercolor on the devil club;
Ah hah!
Is anyone able to explain how the min acoustic level and the minimum fan speed play nicely together in WattMan?
If I set the minimum fan to 1000rpm, does that mean I have to set the min acoustic level below that? Or doesn't it make a blind bit of difference?
It brings a tear to my eye every time i see anyone use Furmark or similar apps.
