The Pascal Titan X and XP Owners Thread
Bit of a bone question this one but if I'm using the two slots closest to CPU on an Evga micro 2 what spacing sli bridge do I need and what's the recommend one if using EK water blocks on the card?
I'm confused how there is 44 pages of "owners" thread. And yet I can't actually find it for sale... Lol.
Only the manufacturer sell them at the moment... head to their homepage.
As OcUK don't/can't sell them... I'm not sure if it would count as a competitor but need to be cautious about posting a direct link.
Measure them with a rule is the best way. If using EK blocks then you cannot use nvidia HB bridge. Can confirm the new EVGA HB bridge fits as I have one in my system.
Just got confirmation of my EK water blocks AND backplates having been dispatched which was a very nice surprise because they had said the 29th for the backplates previously. Bravo EK! :D
still no backplate for me :( and Ive had my block since Friday
Still waiting on EK to deliver the waterblocks and backplates but at least the EVGA HB SLI bridge arrived today.
Welcome and TROH updeated.:)
The Roll of Honour.
Date 23/08/2016, Make NVidia Founders Edition, fenchu, Link
Date 23/08/2016, Make NVidia Founders Edition, SonicB0000M, Link
Date 22/08/2016, Make NVidia Founders Edition, tipes, Link
Date 20/08/2016, Make NVidia Founders Edition, Kered_Dub, Link
Date 10/08/2016, Make NVidia Founders Edition, Stunted, Link
Date 10/08/2016, Make NVidia Founders Edition, Mark_D, Link
Date 09/08/2016, Make NVidia Founders Edition, Zping, Link
Date 09/08/2016, Make NVidia Founders Edition, Trunkey, Link
Date 09/08/2016, Make NVidia Founders Edition, VEGACORTEZ, Link
Date 08/08/2016, Make NVidia Founders Edition, crinkleshoes, Link
Date 08/08/2016, Make NVidia Founders Edition, Rasphelt, Link
Date 08/08/2016, Make NVidia Founders Edition, Alphafox, Link
Date 08/08/2016, Make NVidia Founders Edition, Greebo, Link
Date 07/08/2016, Make NVidia Founders Edition, SherlockHobz, Link
Date 06/08/2016, Make NVidia Founders Edition, Scorpuk, Link
Date 06/08/2016, Make NVidia Founders Edition, dancook, Link
Date 05/08/2016, Make NVidia Founders Edition, Born_2_Kill_83, Link
Date 05/08/2016, Make NVidia Founders Edition, DmitryD, Link
Date 05/08/2016, Make NVidia Founders Edition, occuda, Link
Date 05/08/2016, Make NVidia Founders Edition, Kaapstad, Link
Date 04/08/2016, Make NVidia Founders Edition, Wulfster, Link
Date 04/08/2016, Make NVidia Founders Edition, whyscotty, Link
Date 04/08/2016, Make NVidia Founders Edition, waspy88, Link
Date 04/08/2016, Make NVidia Founders Edition, Combat Fighter, Link
Date 04/08/2016, Make NVidia Founders Edition, danielanthony, Link
Date 04/08/2016, Make NVidia Founders Edition, dshalky, Link
Date 04/08/2016, Make NVidia Founders Edition, Vore, Link
Date 04/08/2016, Make NVidia Founders Edition, spiralz, Link
Date 03/08/2016, Make NVidia Founders Edition, Starvald, Link
Date 03/08/2016, Make NVidia Founders Edition, Cosimo, Link
Date 03/08/2016, Make NVidia Founders Edition, blasterbolt, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Pascal Titan X.​
Any special reason why you did not add me?
Posted #1154, asked again #1245
well just finished installing and testing waterblock , well impressed idle 22c load 32c clockspeeds 2050/5500
heaven 4 bench
on air 4050
waterblock 4187
puts me first in heaven benchmark , still not pushed card yet :)
https://forums.overclockers.co.uk/showpost.php?p=29937540&postcount=4685
Few pictures of block install , decided to use original nvidea screws so i could use there backplate untill ek one arrives.
Might as well add me kaap :)
Only the first card at the minute. Both blocks and backplates ordered, as well as two 6 pin custom cables. Will order the second card when I get all the bits as knowing me will likely be a while lol.
Look absolutely stunning cards. Yet to test but will be seeing how it overclocks shortly.
Decided over my 1080's. Give me a reason to skip 1180 and get the next Titan instead :p
i knew you would cave ;)
BTW anybody fitting EKWB the instructions you get with them are wrong, Im not even sure its the right card although it does say Pascal Titan. I think they just cut and pasted from another card and never checked.
You have to undo every nut screw to get the cooler off not just the ones marked on the instructions.
And it says that there the in and out can be either side on the block. Im not sure about as I thought the ek blocks were one way only now and that the left side (nearest the back of the case) has to be input? ANybody know for sure?
good news my backplate got shipped this morning :)
Im half way through fitting my block, might wait now since its only going to be a day or so.
heaven 4 bench
on air 4050
waterblock 4187
nice load temps, you must have a lot of rads on there?
Haha knew I would as well. Thought fk it might as well enjoy it.
1080 instructions were a bit like that as well. Said to remove the nut type screws with pliers... I had to use adjustable spanner as i didnt have the appropriate socket with me. Was at work.
Let us know when you get it all done. Load temps, clocks etc. Once loop fully warmed etc.
Hopefully my card and blocks/backplates wont be too long and I can get them in and the 1080's sold.
Input and output can be any orientation on their card waterblocks. Only the CPU and or mobo blocks that require a certain flow orientation.
2 rads top rad is push config its XSPC EX420 Triple Fan Radiator using phantek PH-F140 SP fans
bottom rad is a Hardware Labs Black ICE Radiator GTX-Lite 240 push pull using vardar f2 fans
The titan was a pain with the hex bolts , I had to pop to screwfix last night to pick up a 4mm , using pliers as instructions suggest seem daft if you slip. One good thing I was able to re use the hex bolts to assemble block and then use the backplate supplied.
My instructions said "please ignore previous instructions and DO NOT use pliers" :p
They must have made an amendment since the first ones went out ;)
Looking forward to my temps then in the same case. Ive got a 420 Nemesis Black ice GTX in the roof on push/pull and a mayhems monsta 360 in the floor and another blackice GTS240 at the front and still undecided whether to plumb in the 280 GTS in or leave it out. All fans Vardar f4 ER either 140mm or 120mm.
AFter seeing your figures I think I'll leave the 280 out. It was all getting a bit crowded in the case anyway ;)
AFter seeing your figures I think I'll leave the 280 out. It was all getting a big crowded in the case anyway ;)
Lol guessing a few people may have destroyed their cards then.
plum it in :). Cant have enough. 32c is a good temp although id be suprised if it is still 32c with the loop fully warmed and say the card at full load for a good 20-30minutes.
Unless you live in the antarctic.
