Spend most of my time playing tower wars at the moment, which would probably run perfectly fine on a 6600k with integrated graphics...
Put some work into this at the weekend. Early stage though as one of the reservoirs was leaking so I have to rebuild the loop when the replacement arrives. Also plan to re-route a little bit of the tubing... going to go top GPU -> top radiator -> CPU -> res instead of the routing that's there at the moment.
Spec:
6950X @ 4.5GHz
32GB Corsair @ 3400MHz @ 13-13-13-32-1T
Asus Rampage Edition 10
2x Titan X Pascal
2x Monsoon MMRS Res
Hardware Labs Black Ice Nemesis GTX 560
Hardware Labs Black Ice Nemesis GTX 280
Hardware Labs Black Ice SR2+ Xtreme 280 white
XSPC RX480 480 white
Dual-D5 EK PWM pump
EK Supremacy EVO CPU block
2x EK Titan XP blocks
Corsair RM1000i
Bitfenix Alchemy Green cables
10x Corsair ML140
5x Corsair ML120
Caselabs SMA8 Gunmetal
Bitspower Crystal Link tubing
Bitspower fittings
EK fittings
Also some UV cathodes to add (current ones broken in transit) and LED strip that runs off Asus Aura header.
Currently running 400GB Intel 750 + 512GB Samsung SM951 + 2x Sandisk Extreme 1TB + 2x Intel 730 512GB
Waiting on delivery of Intel 750 1.2TB, Samsung Evo 850 2TB and WD Black 6TB drive to add to the system but they won't be here until mid September. The 400GB Intel PCI-E SSD is then going in wifey's new WC build which will be based around Phanteks Enthoo Evolv ATX + HWL BI Nemesis GTX 280 + MSI XPower X99 + 6800k + GTX1060 or GTX1070.
Early piccies, will spend some more time with the camera when the final build is complete.
Legion launch day let's hope the servers aren't chocca
Nice, but what FPS do you get in solitaire?
What's the total cost? Just so I know how many hours overtime to put In.
Where did the second res go when it was filled? Can't see it in the other pictures other than when it's not filled.
Spec:
6950X @ 4.5GHz
2x Titan X Pascal
2x Monsoon MMRS Res
Dual-D5 EK PWM pump
Corsair RM1000i
10x Corsair ML140
5x Corsair ML120
Bitspower fittings
EK fittings
So what will you be using this for? Some high end/heavy image/video editing/3D work? Something more heavy?
