EGR was only £50, That included having them reset the ECU and error codes.
Prob far too much money, but i plan on keeping it so I'm happy enough.
Clutch is dieing and DMF will need changing. Plus the front shocks are needing to be replaced.
Expensive car![]()
[TW]Fox;29968624 said:Dem MPGz tho rite![]()
Thought I'd do an oil change today. Found out opie only sent me 6l instead of 7l. Oh well, good job i had a litre top up.
Your car takes 7L? What car is it?
Just sharing as it might help, I changed the aux belt on my old Mondeo, with the 2.5 you could use a 3/4 socket wrench to pull the tensioner down but it was physically impossible for me to pull it down enough with one hand and pop the belt back on with the other, I needed two hands to hold it down and luckily a neighbour put the belt on the top pulley for me![]()
[TW]Fox;29968795 said:It takes 6.5 litres.
All I've had to do since buying it (aside from servicing of course) is get the rear exhaust hanger welded (£20) and replace a side-light bulb.
Its fairly comfortable, easy to drive, and very economical.
