The lower image has MMI 3G Plus (indicated by the joystick on the top of the large wheel).
Top one has MMI 3G, with no 3D mapping, and a lower resolution display.
Is there that much of a difference between the two?
Mechanically, the cars appear the same. I'm not hugely bothered about having the quattro. For the use it will get FWD will be fine and higher mpg I would expect.
