Volvo C30 T5 running V-power unleaded.
As if you had to ask.![]()
Not bad then![]()
You are pleased because your lights work?![]()
More like I'm amazed they work for being a 16 year old car, and excited to see the interior all lit up! that "new" car feeling you know..
Interior ambient back-lighting barely ever breaks.
Wait til you find the wheel which controls the brightness, you'll blow your mind!(its next to the headlight level adjuster)
[TW]Fox;29968114 said:How much have you spent on this car since buying it?![]()
EGR was only £50, That included having them reset the ECU and error codes.
Prob far too much money, but i plan on keeping it so I'm happy enough.
Clutch is dieing and DMF will need changing. Plus the front shocks are needing to be replaced.
Expensive car![]()
Cars booked in for Stage 1 clutch, flywheel and gearbox oil refresh.
Cost £1300... ffs
