*** The Official Destiny Thread (now includes 2.0 and TTK) ***
Well that was....rusty :)
Cheers guys, sorry I had to run off. On the plus side, I went from 323 to just shy of 329 light yesterday.
Should sneak in another run before RoI....
Shame we couldn't get Oryx down. It was a good evening though. Nice on the light level increase! I think Venom made up a few levels as well.
Moe: "Yeah if you stand here they won't hit you"
Me: "ok" *stands where Moe suggests*
*Guardian down*
:p
I got my 335 artefact and finally got the Queenbreaker's Bow (at 335).
Just realised I am not that far off getting the final step of the Chaperone quest line as well. Will try to get that done before ROI.
Hahaha it worked at 1 time. I still need to do the last part of Chaperone quest (shield bros) if you get that far I believe multiply people can clear it at once as long as they die to a shotgun.
The desirable stats are Intellect & Discipline, preferably with high rolls. After that its down to the perks and the weapon types you prefer. So if you prefer scout rifles like mida, you'll prefer scout rifle ammo and scout rifle reload time. For boots you usually want your choice of machine gun ammo or rocket launcher ammo, again with high intellect discipline. You can use the ishtar commander app or similar to check out what % of the maximum roll your armor has. Destiny item manager for chrome is also very good too and easier to use with a big screen.
Cool to know.
It's all pretty irrelevant right now with ROI round the corner I guess so I'm not gonna worry too much now.
Actually, you'll be able to infuse all Y2 legendary armour up to Y3 light levels, so not as irrelevant as you may think.
Fair point.
So keep an eye out for those 'gold tier' rolls. Everything I have sits in the silver category right now, but like I say I'm pretty strength heavy.
Is the only way to see what 'roll' a Specter/Taken sterling reward is to infuse it?
I haven't been keeping track of anything to do with ROI but have they confirmed details on the armour and infusing? As surely it depends on if something similar is going to happen as before where the increase in light level means an effective reduction in our int/dis/str stats. So infusing armour could increase your light level but really you will want to keep new stuff due to higher int/dis/str rolls.
Along with the light increase to 400 I can only assume we will see the tier 5 stat requirement increase from 300 to something higher.
In other words our current "max tier 12" 335 gear will have the stats equivalent to say a 290 set right now.
This will be the first expansion with the new light level and gear being brought forward so I can only guess that a "Tier 12" capable piece or armour now will still be top tier once infused up to 400 light.
Of course none of this has been 100% confirmed so who knows.... *shrug*
I really hope this is not the case, it will make it fairly boring to get to 'max' light level as you will only have to upgrade a few guns and like 5 armour pieces per character.
Then again Bungie is trying to make things easier so who knows!
I like it, the game feels rewarding rather than punishing now, much more enjoyable, especially having played since day 1 and knowing the 'bad times' we had to grind through.
they're not reducing your int/dis/str stats. All year 2 gear is going to be infusable up to the new light levels.
Nothing much is going to change, apart from the fact the maximum rolls will get higher. Exactly how much higher, nobody knows. Destiny Item Manager wil be removing the % of maximum roll stat from the app come ROI until they have more data to find out what the new max is.
It would make sense for current 'high-rolls' to become average by end of ROI, giving the need to then find the new high-roll current set gear.
Not sure I'll have time for a raid this week, but I have a couple hours this evening from around 5:30.
Anyone fancy quick blast through the NF and 3x CoE runs? Court of Oryx T3 would be good too.
