Chilly start
this morning. 8 degrees
Was going to try the Rapha overshoes out to avoid blocks of ice for feet though despite not having skinny calves or ankles they didn't seal on them with 2 fingers easily fitting inside. Wouldn't be watertight so will go back
Buried myself for the last 10 miles to add .3mph to knock the average into the 17's. Power average slipped a bit from mile 40 so that wasn't happening today.
Left my knee warmers, gloves and cap on a bit too long. Quite clear skies so it warmed up relatively quickly, should have stripped off a bit for Hill Road, Wattinglton. Was wary I'd run low on fluids and being seemingly unaware of how much I'm pespiring in to my warmers has always been the cause of cramp for me, half way round it was playing on my mind a bit. Found a small shop for a top up & plonked some more tabs in
I've learned avoiding excreting salts is the best approach rather than trying to replenish them.
Adjusted my bars slightly as the angle of the drops was causing some forearm pump based on wrist angle, tweaked the hoods so I wasn't over reached. More or less fully recovered from the palsy a few weeks back and no numbness or tingles today. Good to finally have the bike comfortable again.
Also managed to get that rounded seat post bolt out with a sharper bit. So checked it is in fact M6, which it is, and cut a slot in the top so a flathead can get it out if need be in the future. Found a
suitable replacement. Titanium y0
This meant of course I could fit my new Selle Italia saddle which is a significant improvement on the Bontrager stock saddle. Slightly narrower at 135mm vs 138mm but also 145g lighter. Unfortunately, this will please some, the saddle bottle cage mount doesn't fit on the rails so had to revert to a glasses case for my spares again. Though another 150g weight saving by doing so
Which brings bike weight to a shade under 7.8kg
Was wearing a Rapha Pro Team long sleeve jersey today and the rear pockets were a tad small, having all my spares in a jersey pocket didn't help the lack of space. Cue having to stuff some bits up my sleeves
Definitely undergone some degree of fat adaption. Set off fasted and started fueling slightly later than usual. 700 cals for the ride with a 66c/42f/14p split and still beans in the tank to gun the last 10 miles and PR a short climb. (Not 'loading' or eating over maintenance in the day(s) prior).
/walloftext
