- 28 May 2007
At 1440p it would have to be the gtx1070.
The other thing I would be thinking about is a sync monitor which I would say is a must if your buying now. What's your budget for a monitor? Amd Freesync monitors are usually cheaper than there Nvidia gsync equivalents so take that into your budgeting.
Amd don't have an answer to the gtx1070 until next year most likely.
