Well I finally got chance to put all my shiny new gear to good use!
Yesterday, ten hours (got carried away, started at 10am and didn't even stop once for a drink/ciggy/pee... Then it went dark. Oops!):
BH snow foam
TBW with AG Bodywork Shampoo
BH Korrosol
Gyeon Tar
CG yellow clay (bodywork, bumpers, glass and alloys)
DA with CG Hex Green and Dodo Lime Prime
Gyeon Prep wipe down
BH DSW (bodywork, lights and bumpers)
Today, four hours:
BH snow foam
Dry with CG Wooly Mammoth (still not impressed with it, too linty and streaky)
Second coat with BH DSW for the bodywork/bumpers/lights
FK1000p for the alloys
CarPlan Tyre Slyk for the tyre dressing (I prefer it to my Megs Endurance!)
Thorough vacuum inside
Sonax Cockpit Cleaner
Halfords Glass Cleaner
Ta da!
I need a holiday... I'll machine the front and rear screens and apply my Gtechniq C3 at some point, but tbh it looks fiddly so I might grab some Aquapel or something. Either way the flake pop is immense, the paint is practically alive and it really does (finally) look the business. I will add a third layer of wax in a few weeks (either Dodo PH or FK1000p) to make sure it's all watertight when the real weather starts kicking in, but other than that I'm happy.
Thumbs up to Lime Prime btw, which was tremendously good at removing >95% of the swirls (I think the heavy polishing green pad helped) with no hassle at all. It got rid of 100% of the awful rotary buffer trails the body shop kindly left all over the C pillars, and it also restored the glossy black trim on the B pillars to brand new. I'm in love with the stuff! It's so easy to work, stays oily for absolutely ages and you can work it a lot faster than full on polish. Hats off to Dodo, it's a good product. Now, where's my beer?...
