gps cycle computer - GPX ?
  • Thread starter Thread starter Deleted member 54091
  • Start date Start date
Hi all,
is there a simple gps logged which saves by default to gpx format.
looking for something which is universal cross compatible.
i think it doesnt exist. so ive gone on gsm arena and looked for a small phone with gps
ive come across sony xperia mini u. i will install the app https://play.google.com/store/apps/details?id=com.mendhak.gpslogger&hl=en_GB
that will do the job. phone is cheap on ebay and a lot better than garmin edge which i was going to buy.
any recommendation for a bike mount, something similar to the quarter turn mount
I don't cycle enough to justify getting a decent bicycle GPS, but I wanted the option to use navigation. I have been looking for options to use an old phone of mine, but I didn't like any of the off the shelf products (or the good products were for iphone/out of budget.
Found a video last week of someone who had DIY'd a mount and I liked it, so below is the result.
pPKcpZDIo_GSBM4Bojgh6x8Ls6mbKDbVvxvw9XHURSTNzoXzU85St902afkWEkpXDkSFwXQgyS4Ib4K-C9ZJHpMTd1h50YOTj3FfF_igBnQ2Vvhy_hpGF7h9bq0KU6gj3MV_LSOF6R2PItl6leayhZ_wOtR38Mi5AySNx9Dpa2H--NgdibJx8CYKlKamhPZP5dtnxICRUlel8k2aj2nVVWvYtAyX07ybvGMJvSZGVlbUk5zjDGMhbh_erNLHoWdWQjkGj6o1HpJozRBgD8NkvdYAN1nmxjlOZBvr4I_i5ToLSLna7IpV4fhaJv_MAckBbX5MYi2dp651VnLFA3eE4poSSPrN2OuFkX-vMn0XiEFrwdQnYex00sWhsjWfP8IjmZ2oS1vjHKBQxTOyO11QgiOc5GV6RVAovNsG5pbzOEyvEH0e-6_h25sScnhP2ubQPRFH9s53W6C3rWiQx5eQInlGrPOzRpWjMyLoEcaE8_VH7Una1ZXxr8n2FcSDbJzvX0PC_aqaRKlSKHn3xOdkClTFHR5Gmw_oXXxIcgw4ZqrEgPgCpMyP-NhJI2HM6VWK_nrvrxbD8yYmYcp84T5qp4QmR5GsKDo6tbtkuYwG_ZJm_WhTwA=w1698-h955-no
Short video
If you don't mind DIY.
Yes, I was looking at that too but when I found this I thought it was much better (for me).
Main benefits being it's cheap (case £2, adapter £4, mounting arm £3), and easy to adapt if I decide to use a different phone.
exactly so, plus i can double up the phone as a cheap phone to take abroad when traveling.
i was going to invest in a garmin edge, but when i thought about it a cheap small phone would do the same job if not better.
I just wanted to share my new setup with you all.
So I bought a Sony xperia mini its surprisingly small, flashed it with android 6.0 marshmallow from the guys at https://legacyxperia.github.io/
its runs surprisingly well for what i need it to do which is just log GPS coordinates to GPX file which i upload on strava. I have order the garmin quarter turn mount, which i plan to do the above mod/hack.
The following apps i have installed on it.
  • GPS Logger For logging gps coordinates
  • SpeedMeter For displaying speed,i have the logger in the background and this as my main HUD display
  • Maps Me offline maps for moving around to new routes
  • Satstat handy tool to see how many satellites fixes
using a silicone rubber band, but will post a final pic once i get the new mount sorted on my stem.
